Symbols keep disappearing behind swamp
I thought I had the sheets figured out but I used the default terrain to draw some swamp on my map then when I try to put the symbol of a ruined tower on the swamp it keeps going behind it even though I put it on the symbol sheet and that is above the sheet I have the swamp on or so I thought.
If that isn't the problem, use the list command on the entities to ensure that they ended up on the sheet you believe they should be on.
