Geomorph Flagstone
                    Greetings All!
I am relatively new to CC3/DD3 but I am learning (so please any information is good information).
The walls that are included with the Geomorph Flagstone set blend with the flagstone floor a bit much for my taste. I believe they are the lava stone graphic. I have tried using the effects but just can get the contrast I am looking for.
Is there any suggestions on how I can get more contrast or maybe replace the wall bitmap with a different one - say a light grey?
Thanks for your time.
Ed
Ed
There are at least 2 ways of doing this.
The first option is to explode the symbol, which then lets you change the wall fill style. This is a good option if you wish to make a new symbol catalog with the changed walls.
The other option is far easier, but requires you to "cheat" with the fill styles:
- Click the fill style indicator in the top left corner, and select the "Bitmap Files" tab.
- From the Fill Style Name dropdown at the top, find the new fill style you want. Select it, and copy the file path from the "file" field
- Now Select the "Stone Lava Cooled" fill style from the selector, and paste in the path you copied from your prefered style
- Hit ok
That's it. All instances of the "Stone Lava Cooled" fill style now uses the new bitmap you selected. Rember that this affects ALL instances in the map though. If it doesn't show immediately, try a redraw or zoom extentsNote that you can safely rename the fill style if you wish, it doesn't need to continue to be called "Stone Lava Cooled", but the important part is that you change the existing fill style as outlined above, and not create a new one.
And if that is indeed the case, what happens if you insert a map into another map (then immediately delete it to get the inserted maps fill styles in the new map) where there are two fill styles with the same name but different definitions (like a different bitmap file used for the fill)?
So if you make changes in a map, but don't save it as a template and use that particular template later for another map, only that one map will have the changes in it.
I am not certain on your second quesiton, but it seems to me the first style will be overwritten.
