Using CC3, I started a new drawing with three floors. Now that I'm into it, I've decided I'd like a dungeon level as well. I can't figure out how to add another floor to this drawing. Can anyone help?
Adding another level after the fact is tricky. I would do a new set of maps at the same size, just with the added floor, and then use Clipboard Copy to copy my old floors into the new drawings.
Draw up the first floor with major areas like the doors and stairs.
Save as to filename 'second_floor'.
Save as to filename 'third_floor'.
That way stairs line up.
Delete exit doors from the floors above ground/first, unless you are adding outdoor stairs.
Edit each floor's map separately.
Export pngs from each map. Now you have a 3 level Inn or other building.
I used to have examples of this, but I haven't updated them onto my new site yet.
