Edge fade problem in DD3+
Hi guys and gals!
I've used CC3, DD3, etc. since it came out, but with my newly bought CC3+ (with DD3+ Upgrade, Vesion 3.67) I ran into a problem with the Edge fade option ... it seems to me it doesn't work at all. Any suggestions to what my problem might be?
The earthen path is on the OUTSIDE sheet, the effects presets are the "SS2 Bitmap A 250x200" (the actual map is 120x120). There I added to the OUTSIDE sheet the "Edge fade" effect with the (not ocurring) effect visible on the screenshots below (i did two screenshots with two diffenent distance settings to illustrate that there is no visible effect - at least to me - at all).
Thanks a lot :-D
Thanks a lot :-D
