Red cross symbols, sort of
So, I was messing around with some of the symbols from the July 2008 annual and noticed some odd behavior. The symbols show up just fine in the symbol catalog, but when I select them for placement, the symbol appears under the cursor as a red "X", even on brand new maps with no predefined symbols. However, once the symbol is placed, it reverts to looking like it should (i.e. the red "X" is replaced by the actual png image). Now, this isn't that big of a deal, as it only makes placement slightly more difficult than normal, but I also noticed that when I go through the symbol manager to edit the symbol, the edit window contains a red "X" rather than the image (the symbol manager itself displayed the symbol normally) which makes symbol editing very difficult.
Any idea what's causing this odd behavior and how to fix it?
Have you seen it happen with any other catalogs? You may wish to try to reinstall that particular annual.
If that doesn't help, you should contact ProFantasy Tech Support
