In wich way has created this map?
                    Hi to all. I' m a new user of this fantastic forum, and this fantastic software!! :P
I' m sorry for my bad english, because I' m not english.
I' ve got a question:
In wich way has created this map? They are not normal symbols, and I want more informations. Please, tell me about this map... I really like that type of map!!
http://www.profantasy.com/library/default.asp?Keyword=southern&PP=9&Start=1&Image=0
I want only that tutorial, I want make a map like that... i really like that style.... Is there a very simple tutorial??
Or someone can explain me how to make map style that?
Allyn Bowker can be found here
http://www.darkleagues.com/
He may still have the descriptin of how he created the map he might share with you
Also he is working on updating the Tomb of Ultimate Mapping for CC3 and when it comes out it should have the tutorial as well
Also, the reason I posted the link to download the map is you can see that he uses no symbols. and by down loading the map, you should be able to 'dissect' the map and reverse engineer if you will.
I' m downloading the map, if I have problems I tell you! Thanks again
Another question:
This map --> http://www.darkleagues.com/fantasymapping/maps/overland/SouthernMarch/SouthernMarch1400x1000.htm
is different from the first that I' ve got posted in first post... why?? Is it CC3 or CC2??
