Wall Symbols not snapping to all lines
I'm pretty new to Campaign Cartographer and I admit I don't know what I'm doing. My problem is this. I've drawn a little keep, and I used the Room Tool to draw two sections. But, I drew most of the walls with the line tool. For some reason, doors and windows will snap to some of the lines I drew with the line tool but it does snap to others that I know I drew with the line tool. I drew all these lines the same way at basically the same time. Why would this be happening?
Any help appreciated,
Danny
    Check the layer of the lines (You can do this with Info --> List). The wall features will only snap to lines on the WALLS layer (To make it easy for these objects to snap to walls without trying to snap to everything else in your drawing).
    You can change the layer of any line y using the change properties command.
    The reason it works on some and not others is that when you use the more advanced tools, they often set the sheet and layer for you, but the basic tools, like line, simply use whatever is currently set, which is bound to differ from time to time since you have been using other tools that changes this, therefor you end up with lines on several different layers if you don't pay attention to the current layer.
  • Thank you very much! Your response was prompt, accurate, complete!
    Glad to be off assistance.
    Happy mapping, and welcome to Campaign Cartographer and the forums.
