Path/Tracks Error, Dungeons and Schley
The "path, cart tracks narrow" and "path, cart tracks wide" tools display the red X error box rather than texture/fill they are supposed to show. How can I correct this?
    Have you moved/deleted any of the files from inside the Bitmaps subdirectory? (Inside the installation folder for CC3, Inside the data folder for CC3+)
    This drawing tool is set up to use the fill style 'solid 50' which is defined in just about every template out there, and is one of the 'core' fill styles of CC3. The file should be located in #Bitmaps\Transparencies\solid 50.png.
    If the file is located in the correct place, also check that you haven't deleted the fill style definition from your map. Simply click the fill style indicator, go to the Bitmap Files tab, and look for the fill style called solid 50. If it is missing, simply create a new fill style with than name, and point it to the file mention above, making sure it is set to 'alpha transparency'
  • I haven't moved anything around but thanks for the fix. Do you have a set of effects you like for schley tracks?
