Some help with effects please
Hello all,
Been getting back in the swing of things.
Running into an issue, with battle mat.
Have CC3+ and DD3 with a few things from download section.
I have a stream going down the middle of the map, had some issues with getting trees on top but got there.
It would show on top then redraw under, but it is working.
I wanted to blend the stream with the land to help the dry grass to water changing.
Tried Blend, Blur and a few more, but no real luck.
Fairly sure I am missing something simple.
At first I had the water as a floor, then redid as water, was not sure how to get the fractle working with the water tool.
The tried various effects to blend ground with land.
A drop look like stream was lower would be cool as well.
Thanks for any help,
Lee
Lee
try adding the effect "inner glow" with color black and a small blur size to the river. (example is the first image).
For blending in into the land, you could take a look at "Blur, apha", looks like the 2nd image.
Just two ideas
