CC3Plus Update cannot locate install
I'm trying to install update 1 for CC3Plus, but when I try to do so I get the error message "Sorry, your previous CC3+ installation could not be located".
I've tried pointing the installer at the CC3Plus folder in Program Files (x86) and ProgramData, but neither work.
I even tried uninstalling the CC3Plus installer from January, and then reinstalling the most recent installer, but had the same issue.
Has anyone else had this problem and know what I need to do to rectify it?
There are a few registry keys that are required in order to update the install, however some of these keys are not installed until after you launch the application with the account doing the install.
That means that if you are installing using an admin account, then you need to be sure to "run" CC3 as the same admin account at least once. The easiest way to do that is to "not" untick the box post-install that offers you the choice of launching the app.
I personally skipped the chance to launch CC3 after the install, because I knew that there was an update to install too. It was skipping this seemingly unimportant step that caused the problem.
Thanks for posting the solution!
Google search that let me find this: previous cc3+ installation could not be located
