Error Message
stuartwaring
Newcomer
I have just started to make a DD3 map, but when i click on the default water button (or wall, terrain, floor or cave), i get an error message saying "No Matching Drawing Tool - There is no draw tool matching your selection in the current draw tool style". Any ideas as to why i am getting this error, and how i can fix it?
Thanks
Thanks
Check the File Drawing Properties. What is the drawing style for the map? If you are working with DD3, it should be "Dungeon DD3 Color".
The style was CC3 Dungeon, i have now set it to DD3 colour. Not sure how it got changed though.
Thanks for the help
I started a new map, on a dd3 template, but i get the error message again after i have added some symbols from CC3 (as opposed to just the DD3 symbols). Any ideas why, and how i can get around it?
I want to add some trees into my map, but am worried that if I use the tools from CC3, I will not be able to use the tools from DD3 afterwards
If you are still having problems, we'll need some more specific information. Can you post your map here? Which drawing tools are you trying to use?
