Bitmaps and Res
SkidAce
Traveler
I notice that fill styles normally have four bitmaps, normal, HI, LO, and VL.
I understand these are high lo, etc.
But what are they used for? When I made some fill styles, I just chose the HI version and pressed on.
Are they supposed to be selectable dynamically by CC3? Or do we manually choose which one we want on a per map basis?
If you need more control over which version is shown at which resolution, you can do so in the Display Speed dialog > Fill Style resolutions (Advanced). These settings will save with the template or drawing.
