Altitude key appears on top of map after export from Fractal Terrains
After a lot of experiment I've got a decent export of the Hammer projection from Fractal Terrains to Campaign Cartographer. I am using the latest version of both programs. The trouble is that the Altitude key gets superimposed on the map. I'd much rather have it in the blank space on bottom left. I can't figure out how to move it in Campaign Cartographer. I'm sure there is an obvious answer to this, but what?
If you need help on performing the various selection types, I recommend you check out the Editing chapter in the manual, it contains a detailed tutorial.
I hide and freeze all layers that aren't the CBAR ones. Then erase or move them.
