Creating oval maps
I'm trying to make some maps for a 1st edition Metamorphosis Alpha game. In the 1st edition, the different levels of the space ship are oval in shape, and I'd like to create a map that is overall oval in shape. Right now, all the maps I try to make are rectangular. Is there a way to create oval maps?
You can, however, create an oval on the background map and constrain the area of the map to the oval. This is no different than if you were to draw a large oval on a sheet of paper. Is that what you are after?
R A Jacobs
Learning CC3+ @ Funny-Shaped Dice
So how do I draw a perfect oval, 50 miles by 25 miles in campaign cartographer?
Thank you, BTW, for your help. I greatly appreciate it.
Alternatively you can type in your coordinates, use the pre-fix @to set relative coordinates:
- Start the Ellipse command (ELIPP)
- click the center point.
- type in @25,0 for the x axis endpoint (half the width)
- type in @0,12.5 for y axis endpoint (half the height)
Voila, exact measurement ellipse done.
