Text along a curve
Is there a trick to putting along a curve that curves down instead of up? Every time I try it's upside down and backwards.
    The text will always follow the line from start to end, so basically, you draw it in the same direction as you wish the text to go.
    If you need to, you can reverse the direction of an existing line by using the FLP command to reverse the direction of the existing line. Also note that if you are using a circle arc for your curve, it can only go one way, so you need to convert it to a path with the Line to Path command (LTP2) first.
