Using touch for scroll
Hello
I'm a mac user and I've bought a Surface pro 3 for using campagn cartographer.
Unfortunately I was'nt able to find how to scroll the map.
I'll like to use the pen to draw and use the tool, the finger to scroll (or zoom) but don't found how to archive this ...
does some one have a idea for that
Tks
Guillaume
Tks
Guillaume
I've found the best way to scroll on the surface is to use the PAN command. To get quick access to this, you can add it to your right-click menu by adding the line
Pan:~PAN;
to the rclick.mnc file found in the System directory inside the CC3 installation directory (Or cc3+ data directory).
Note that this will not allow you to use pan mid-command, since most commands ends when you right-click. To be able to do that, you could add an icon for the pan command to the main toolbars as well.
Sadly I'm no expert myself, but I dabbled with them when I first started playing Elite: Dangerous. I'm not sure if you can map touch gesture controls with them, but it's certainly possible to remap every other kind of control.
Will try that this night ...
Using this idea above I've use TouchMe Gesture Studio with allow to add some shortcut with touch gesture (3, 4 or 5 finger)
I've use the 4 fingers/tap left to send P+A+N+Enter to the front program
It's not the best solution but I can use it until profantasy will understand touch input
