Text Along a Curve
                    I'm trying to use the Text Along a Curve command to place text on a circular token I've made in CC3.  The selected path is an center/radius defined arc that traces out the bottom portion of the token's circle.  The problem is that the command writes the text mirrored (which means that it considers the start of the path to be the opposite side as the arc definition) and that it's written with the text to the outside of the curve when the baseline coincides with the curve (i.e. the text is upside down).  How do I go about setting things up so that the text is written to inside of the curve and in the right direction?
One way to work around the problem is to draw a guideline on top of your line, and let the text follow the guideline instead of your real line. The "Text Along a Curve" can even delete this guideline automatically.
I'll look into using a substitute guideline instead of the arc. At the very least that should give me more control over what CC3 considers the start and end of the line.
Edit: Darn. I thought that did it, but it doesn't appear to change the direction of the text. I've forgotten how to do it. Bangs head. Stupid work, I'm forgetting all the important stuff.
