CC3+ Bug
I have installed CC3+. When I bought it, I didn't realise it was an Early Adopter edition, I thought it was polished software.
I installed it to D:/Programs/Profantasy/CC3+
It's working, but the symbol catalog buttons dont work. The symbol boxes that run down the left side of the program are all empty.
When I click the symbol catalog switcher buttons across the top menu, I get a popup where "Available symbol catalogs" are displayed, but that box is empty.
If I click the Advanced>> button, and then browse, i can manually drill down to a single symbol catalog, which is then given an address like "@Symbols\Maps\Filled\Borders.FSC"
If I click OK, I am prompted to save settings. I save, but they dont stick.
How can I fix this?
How can I fix this?
I would also be somewhat suspect of the use of a special character ("+") character in an installation path. The default installation path is "C:\Program Files (x86)\ProFantasy\CC3Plus\" Take note of the fact that ProFantasy even uses "Plus" instead of "+".
R A Jacobs
Learning CC3+ @ Funny-Shaped Dice
Can you also confirm that you installed ProgramData to \ as well? Just wondering if you've got the Program installed on \ but the ProgramData (such as the symbols) installed on C:\ and if that is perhaps messing things up.
There is a file in your installation directory with the filename "@. In my case, it contains the path to where I had the installer load the CC3+ program data. @ represents that path in your example @Symbols\Maps\Filled\Borders.FSC".
Hope this helps...
R A Jacobs
It's the program data I had changed the install location.
So, i have the program executable files in C:\programfiles (x86), and the data on drive.
I just uninstalled and reinstalled with the same setup.
On first run, the symbol catalog buttons worked properly. When I shut down the program and re-opened it, they were blank again.
That's where I'm stuck now.
The @.ini file does include the correct folder.
PS: I misremembered the folder name. I use CC3Plus as the data folder's name, there's no "+" symbol in it.
Make sure you let Ralf know your system information too.
Jay, thanks. How do i contact Ralf?
