Exporting FT3 to CC3 - land disappearing
I'm attempting to export an FT3 map to CC3. On the FT3 map, I have a number of lower-elevation lands, near the water level. However, when I export to CC3, those land show up as water, and it's giving me fits trying to fix it. Any suggestions?
Thanks in advance.
Thanks in advance.
Sea
Land
Should be the correct order. Top sheet is drawn first, then next sheet, on down the list. The bottom sheet in the list is drawn last.
Any other ideas.
1.
- first raise your water level by 1000ft again, putting it back at the 0ft contour
- Then do Tools > Global Raise > Ladd Offset > 1000ft
Basically you've now raised the whole world by 1000ft, instead of lower the water level by 1000ft.
2. Edit the CC3 export setting
- On the third tab "Detail Level" you'll find the option "Altitude relative to water level" . Check this, then redo the export
Either way, a CC3 export should now show the coastline and low elevation areas correctly.
