New to cc3 need help creating deckplans
Im looking for a way to show the grid on the basic mat so I can make a deckplan with some even polygonal shapes (rectangles and such) and I am having issues making sure all my ship parts are evenly spaced on the proper pieces
2. Set the current Sheet to "GRID" and make sure that the GRID Sheet is not hidden (the right box has an "H" in it if it is hidden). If you don't see a "GRID" sheet in the list, add one. Just make sure it is near the bottom of the list.
3. Click the "Grid" button to the left of the left of the Symbol Catalog.
4. Select your grid options.
5. Click Apply.
You should now have a grid on the "mat". As long as the Grid is not set to hidden in the "Sheets and Effects" list, it should remain displayed.
R A Jacobs
Learning CC3+ @ Funny-Shaped Dice
1. Copy the hull outline to each deck layer.
2. Create a layer that only contains the hull outline and put it towards the bottom of the list of layers. In that way, it is "on top" of each layer beneath it. (This is the approach I would try first)
Let me know how it goes.
R A Jacobs
If you have Annual 27 it is all about ships and there is also a videos on ship building by Joseph Sweeney, (Space ships but the same techniques)
KenG
As for the annual, you need to buy The Cartographers Annual Vol 3, containing issues 25 through 36.
Their copyright policy a good deal more generous than the likes of google
Also thank you guys so much for being so helpful!
