Custom Dungeon Tiles Catalog?
Greetings Everyone.
I've recently picked up CC3 and I was trying to figure out if there was a way to create a Symbol Catalog out of tiles that I have created in CC3. I play using 2.5D Dungeon Tiles, so when building dungeons they are very regular in the components placed, and currently I either create a bunch of tiles on the map then copy the sections one at a time that I want to place in the Dungeon, or I just manually build it, but since each component is specific it would be much easier to build a catalog of the components and place them.
For instance, I use pieces such as a 3x2 Straight Corridor, a 3x1 Corridor, a Corner section, 2x2 Room with Door on the left, etc. Sort of like building big maps out of Battlemaps, but scaled down in scope a little.
Is there any easy or simple way to setup a catalog of these individual room pieces to use? Or am I doomed to copy and paste?
- Zeruul, Novice CC3 User
You can also turn these pngs into a permanent catalog. Instructions can be found here.
