Scale Bar when Exporting from FT3 to CC3
I have been toying around with FT3 to get a good base world for my fantasy campaign. After a lot of tweaking I have finally started to get what I wanted down. The problem I have is that when I include the Scale Bar it always lists the Scale Bar as 200 km/miles regardless of how much the view that I export is zoomed. This causes some problems when I try to export Multiple Files since all the maps have the same scale regardless of what scale it should have.
Anyone else have this problem and do you know how to fix it? I am pretty sure you used to get the proper scale on the Scale Bar before.
    I don't know of any workarounds/fixers other than to export without a scale bar, then add them manually in CC3 afterwards. Unless you are exporting a very large amount of maps, this doesn't take too much time.
  • ChorpaChorpa Newcomer
    edited February 2015
    Yeah that is the only option I can see now. But was hoping that I wouldn't have to do this since I was planning to do just that, exporting a large amount of maps. And even if I don't it is still hard to know the scale of the window that I export.
    Edit: I tried to install the old Fractal Terrains Pro and there it worked. The scale bar automatically adapted to the scale of the window exported.
