DD3 changing map scale
I've noticed that when I'm making a map in DD3, based on the dimensions of said map, it will automatically scale to 1 square = 20ft x 20ft, or 1 square = 10ft x 10ft for a smaller map. I'm curious if it's possible to change this value to 1 square = 5ft x 5ft
    Could you elaborate what you mean by 1 square? DD3 doesn't really measure anything in squares, and the scale is always in feet (or meters, if you used a metric template)
    If you are referring to the grid, you can add any grid you want. Just select hex or square overlay from the draw menu, and add a grid in whatever size you desire. If you have an existing grid, remember to delete it first (The Grid Sheet is usually Frozen, so you may also need to thaw it before you can delete the existing grid).
  • Posted By: MonsenCould you elaborate what you mean by 1 square? DD3 doesn't really measure anything in squares, and the scale is always in feet (or meters, if you used a metric template)
    Thanks, that's exactly what I had been looking for!
