First map. The White Wolves Island
Hi!!. I have just finished my first map. Here I show you a part of the White Wolves Island. I still have to take care of some details, like adding names and stuff, not structures since it is not an island habitated by humanoids. But also I have a few problems:
1) How can I change the size of the Sea and Tundra texture? because I think they look too big compared to mountains and trees.
2) I have other smaller islands (not here) which I would like to fractalize a little bit, but when I do that only the landmass fill fractalizes, while the outline remains the same. Any ideas how to fix that?.
I hope you like the map!, specially the glacier coming down the mountain that finishes within the bigger lake.
Greetings!
Greetings!
To edit the size of the tundra fill, click the fill style indicator at the top of the screen (FS: Name of current fill style). On the Bitmap Files tab, locate the fill style Tundra_MS and change scale to something more to your liking.
I really like how the small rivers to the right combine to a bigger one. Same applies to the top left rivers. You can also fractalize the coast a little bit by selecting the "Default, Land"-Tool and then press "E" to edit the coastline. By simply inserting more nodes you should get the effect you want. Also you might want to think about breaking these pattern while placing mountains around lakes. There are a lot of straight mountain lines that look a bit odd. If you would reproduce the mountain shuffle in the bottom (middle) your map would benefit from it a lot.
happy mapping
Malmo3000
