Error 00000045A loading XP Module: XPDWG2.DLL
I was having some odd problems with CC3, in part I think because I originally installed to a different directory.
I first uninstalled just about everything from ProFantasy
I did not uninstall:
FT3 Update v3.12
Then I started installing everything again.
Campaign Cartographer 3 Plus
Character Artist 3
Cosmographer 3
Source Maps: Temples, Tombs...!
I received a couple of script errors during the install. Something about a value not being an integer.
At this point I looked at my install sheet, and did not see if I installed the CD3 High Resolution Bitmaps or not
So I installed the High Resolution Bitmaps
That asked if I wanted to repair or remove
I said repair
The install then tried to start up CC3
I get the Error 00000045A loading XP Module: XPDWG2.DLL
If I click OK, CC3 starts up, but many things are not loaded
If I click the CC3 icon inside, the left icons are there.
However, it shows CD2 not CD3.
I I click the CD2 icon I get the error: Compaign Cartographer cannot perform the command: LOADCD3
If I uninstall everything, again, what order should I install the packages?
When I reinstall should I install the high resolution bitmaps?
