Is there a good source for PA mapping in CC3(+)? I see a modern set of map icons, but I am looking for specifically PA and high-tech stuff. Anything like that? Thanks.
Cosmographer 3 has some high tech icons that you can use.
Some of the Annuals had some high tech stuff. The free annual sampler that has some of the annual issues for free, and one is the High Space one which you can use with Cosmographer 3 to make underground bunkers, etc.
The CSUAC, which, is free has some modern map and futuristic icons that you can use.
I also recommend you search the Dunjini forums for map icons as they have a lot of modern military vehicles, etc. on it that you can use in CC3
If your looking for anything in particular and none of those help just post exactly what you want and hopefully someone can find it.
