CC3+ question, newby for sure
Hi!, I am working with a map in CC3+ and I just finished the details of an island. Now that I finished I would like to fractalize a little bit more the coastline since it doesn´t look very real... the problem is that in Mark Schley style the landmass has a characteristic outline, which I would like to fractalize as well toghether woth the landmass, however when I do that it only fractalizes the land, but not the outline. Any quick idea how to fix that?
Thanks!
    Hi, here are two ways to do this:
    1. Fractalize the landmass first, then hide the LAND sheet and fractalize the coastline with the same settings. As long as you completely restart (ESC, click the button again) the fractalize command between the two operations, the results should be the same.
    2. Delete the coastline first, fractalize the landmass, then use the Change Like Drawtool (right-click the Change Properties button to find this command) on the landmass to change it back to have the coastline again. This has the advantage that it can be used on several landmasses and islands in one go.
