CC3+ and CC3
I have been working on some new maps with CC3+ and like what I have seen thus far. Question, should I be able to open old CC3 maps with CC3+ and edit/change/add symbols etc... with the CC3+ symbols because I can. I have just found this out when I opened an old map.
    CC3+ supports everything CC3 did, so yes, you should be able to open old CC3 maps just fine and edit them in CC3+, including using new CC3+ feature son them. Do note however that if you use any of the new symbols or fill styles from CC3+, these won't be visible if you open the map back up in CC3.
    Also note that since the addons doesn't support CC3+ yet, if you have made a map in CC3 using resources from any addon, the map will open in CC3+, but the symbols will be missing (red X's)
  • Good to know. I'm glad I saved my old/modified map under a different name just in case.
