iso map added, Perspectives, lawn under trees
🖼️ 280 images Cartographer
I was fiddling with Perspectives late on Tuesday night. I got the path up to the cliff wall okay. Then I tried putting a green lawn area under two trees and a fountain using sheets.
They go under the lawn no matter what I try. front to back, different sheets.
I've attached the png file and the fcw zip file.
Suggestions ? Thanks !
[Image_3867]
All you need to do is to move your lawn sheet one step up in the list, so that it is drawn before symbols.
edit: Sigh, it worked that time. Thanks.
My project in mind is to use Perspectives and the iso dungeon annual to make an adventure.
I may or may not be successful, but I'm going to try.
The bit upper left of the cliff wall is a dragon head and two wall angle pieces. They flank a hole in the wall.
I decided to add a gray ( color 250 ) background and a lake to the map.
edit 2: added some symbols to the background. The map is 45% of the exported size.
~Dogtag
