CD3 Missing Bitmaps with House Tool and
Many of the bitmaps are showing as red "x"s with the House Tool for both Bitmap A and Bitmap B styles. Not all are missing, but most are.
I discovered this when I went to use the House tool and make some custom hovels in a slum district.
If you need to use the house tools on non CD3 templates, you need to import or create the appropriate fill styles.
I might have to start the map over? I tried importing the bmp fill style but nothing happend other than that instead of red "X" I got a plain background color.
If you have red Xs showing in this file, you're physically missing the fill bitmaps and will need to reinstall CD3.
If you can see all the fill styles, it's a problem with your specific map.
You can try copying all the content in your map via the clipboard into a new map created from scratch - that might fix the fill styles.
Hope this helps.
save as map001, make a few changes, save as map002 etc. continue until done. Then save as map.fcw and map.bmp.
I then use Irfanview to save as the map.bmp as map.png I upload a zipped version of the fcw file and the use Irvanview to make thumbnails. Type up the html, then upload.
This way I can backup and take a different route if I encounter a problem.
