Can't see map background in new drawing wizard
When I create a new map, using SS4 Dungeon of Schley, and get to the map background section of the new drawing wizard, the background preview doesn't change from the default, no matter which background I choose. How can I fix this?
I spent one hour to try to understand why navigating the Fill Style combo Box in New Drawing Wizard the image didnt change. So finally i went into this post
i note the same issue in CC3 New Drawing Wizard CC3 standard overland
JimP said : Just finish the map wizard, it shows up then.
i think It's not a valid answer and I suppose it's a bug to be fixed! what's the meaning of a picture box on the right if it doesn't change when fill style change?
there are 40 styles in the combo and i think it is very useful to see the result directly on the wizard
another question: under fill style combo there's a color box but it's always disable. why?
many thanks
einmarbo
It has no real effect on the map. I always adjust the background anyway.
your answer is true and the issue has no effect on the map. but i think, looking at the form, there's a bug. Fill Style map isn't refreshed
after Wizard, as you correctly said, i can modify the background.
The file you posted fixes one of them but not the others. Can you post fixed versions of all the other SS4 templates?
In the meantime, if you want this changed in your installation, just open the templates in CC3+, rename or hide that sheet in question, and save them.
