trouble with the Herwin Wielink add on
Two things: first i cant get the font to appear in Tolkien style. i select this font for words but it looks like plain Times New Roman , nothing special.
second, I want to add sheet effects for the borders called "TERRAIN DEFAULT, SCRUB" and TERRAIN DEFAULT, TUNDRA". These sheets need a faded outline yet are not listed in the "sheet list" and whenever I try to manually add them, nothing happens (maybe i'm using the wrong name for the particular sheet?)
Thanks much in advance for any advice. If it matters I use windows 7.
I'm not getting the same problem with the scrub and tundra.
TERRAIN DEFAULT, SCRUB defaults to the TERRAIN GRASSLAND sheet and the TERRAIN DEFAULT, TUNDRA defaults to the TERRAIN MARSH sheet. Both of these sheets have a form of edge fading. If you want them to go to different sheets you either have to make new drawing tools or use the edit properties tool.
For the font, what I had to do was go to the CC3 directory and go into the Fonts folder and right click, install to install them in windows to get them to show up properly in CC3.
Some fonts can be installed correctly and not show up because of a change of how Windows handles font metadata Microsoft made back in XP.
See this thread as I went into detail about the problem and how to fix it,
http://forum.profantasy.com/comments.php?DiscussionID=4325&page=1#Item_7
Make sure you don't end up multiple copies of the font installed if you go to install it as that can cause problems with Windows. See the thread I mentioned for how to deal with that and to make sure your fonts are installed.
