Changing the size of a map
So I finished a map and I didn't use as much space as I originally though I would need. How can I change the size of the map? For example, lets say I begin with a 500x500 map but I really only need 500x475?
Other options are to create a new map the desired size, and either copy over everything from your old map (except the map border and the background), or to delete the map border on the old map, and copy over the border from the new map you created. Note that if you have made custom effect settings for the map, these will not automatically be copied over if you go with the option of copying everything to a new map, but you can save them as a custom setting in the old map from the sheets and effects dialog, end then load this setting up in the new map.
