Setting an overland map scale
                    I'm sure there is an easy way to do this, but I seem to be mentally blanking on it.  Basically, I've got a jpeg of a hardcopy map loaded into the background and I want to trace it in CC3, but then I can't remember how to set the map scale such that the distances between cities etc come out right.
Please save my sanity and remind me how to tell CC3 how far I want it to be between 2 points on a map!
Thanks
John
Thanks
John
1. Use
Info->distanceto measure a know distance on your map2. Type
scale[enter]3. Select the image
4. Hit
D(Do It)5. Enter the real distance divided by the measured distance (Just enter the expression, CC3 will calculate it for you)
6. [Enter], [Enter]
You can also play with the map scale by changing drawing units:
File->Drawing Properties->Drawing Units1. Draw a box the same dimensions as map
2. import map and make it fit the box
3. Then set your symbol scales as to map size ( example 1000miles across = symbol size 1, 500 miles across = 0.5 etc etc )
