Auto filling in climate terrain
I have exported a climate map of my main continent, is there a way to tell cc3 to fill in one of the climate colors with a terrain?
Say fill in yellow which is desert with the desert terrain type.
What I did:
1) Clicked on the "Change Properties" icon
2) Clicked on the edge of one of the climate areas. When I did this, it selected that climate and the one next to it. Significantly, the command line (at the bottom of the screen) said "Select entities (2 picked)" But I only wanted one entity. So I need to unselect the one I don't want.
Since I'm in selection mode (because the command line says "select entities") I can right-click anywhere on the screen and I get a menu -- this is a really powerful way to control exactly what is selected. I hover over "Combine" and it shows me "And" "Or" and "Not". Whichever of these are selected determines what happens with my next selection. Since I want to get rid of one selected area, I'll click on "Not", then I'll select the edge of the entity I DON"T WANT to change.
Now I should be showing 1 entity picked.
3) Do it and change the fill style in the dialog.
Does that make sense? That pop-up window will allow you to select by color or fill style, or a host of other things. It's really powerful and once you get a handle on it using CC3 will become much, much easier.
Steve
THe best way to learn here is to try the tutorials (I'm assuming you've worked through them) and then play with CC3.
Steve
