I want to draw a world map over a climate-showing ft3 map. Also, when I open the file (converted to cc3) I get stuck with the dungeon tool set. How do I do these things?
You should be able to copy everything from the converted ft3 map into a new cc3 map that was created with the style you want. If you need detailed directions, ask.
Note that when you copy, the original styles will get copied over as well, so don't expect the copied map to change, but all the styles from the new map will be available as well.
Steve
