Sheets / Layers
Can anyone let me know if there is a way to identify easily on which Sheet and Layer is an object ? I found out a hill area I made is on a "Outside" Sheet and I don't know why, can't find where to find this info (except through Hiding sheets) and how to change the sheet emplacement of the object ?
Thanks
Thanks
2) His the "change properties" button (on the left in my setup), select the item you want to change. A dialogue window will appear. Change the items you wish to change (make sure the tick box is checked), then hit ok.
