Wall Cutter leaves white 'scratches'
UKgnome
Newcomer
I put down a tower in CD3, used the floor plans to create the floor plan and then created a circular room in the tower. When I used wall cutter to cut a hole in the wall for a door it did so, but also seems to have cut out little pieces of the floor so I have white scratches.
This is the first time I have tried this so it is quite likely I am missing something obvious.
I did save and reopen the map just in case it was a redrawing error.
I do think the going wrong is me
It is because I plonked a room on a floor and the program cut a circular hole in the floor and the edges didn't quite match.
Now, I assume a better method is a circular drawn line as a wall.
