Pictures not showing up
I just got CC3, CD3 and DD3 and love them! However, a lot of the symbols and other pictures/textures are showing up. I've tried reinstalling with and without checking the clipart box and can't seem to fix it. On the last reinstall I went in this order: CC3, CC3patch, CD3, CD3 bitmaps, DD3, then the fantasy floorplans pack.
This is what I'm getting when I open up some of the files:
http://www.voidgamers.com/images/data/photo/terrain/scenery/DLMOS-screenshot.jpg
Any advise would be greatly appreciated,
David
David
As for that particular example map, I noticed it uses a lot of fill styles from issue 16 of the Annual (This was the "Example City" issue, which was a preview of what CD3 had to offer). Looks like a normal CD3 install doesn't install these fill styles for you.
Try the "example 2" file instead. That seems to be made using proper CD3 fill styles. If that looks ok, I think everything is ok with your installation, it's just example 1 that uses Annual fill styles.
Actually, on a closer look, the "example 1" map IS the actual map from Annual 16, so as long as you don't have the annual, this won't show up properly.
Here is a corrected version.
