Deck and Pier parts
  • KenGKenG Traveler
    Is there a better way to place all of the symbols?
    There are a total of 14. They are all at a pretty high resolution.
  • 10 days later
  • Yes. The way to do it is to put everything into a ZIP file and then just post one image as an example OR put all of them into a graphic program, position them so you can see all of them and then do a screen snapshot and post that as "This is what all you get in the ZIP file". You can use 7zip, WinZip, jZip, iZip, PAK, ARC, or any other archival/zip/compression program that you want.
    By putting all of the images into a zip file you also help everyone to keep things straight on their systems. If you put everything into a folder and then zip that folder you can also have your disclaimer, notes, history, etc... in the folder with the images so people know who made them, how you made them and so forth. You should also include something like the GNU license or MIT license, and so forth so people know how they can use your images. By posting the group photo of your images people can look at them but not use them until after they have downloaded the zip file and read the licensing part too. :-)
