source maps font problem
I just downloaded the source maps and the fonts on them are not displaying correctly in CC3, viz. they are oversized, running into each other, running off the edges of the map, etc. Does anyone know how to fix this? See attached for example. Thanks.
To fix it on your system, you'll have to edit the text in the maps where it happens. Use LIST or KEEP to check the size of the text entity in question, then make it a little smaller with the Change Text Properties command.
