Character Artist 3 Changing weapon layer
I'm sure this has been posted somewhere and i'm sure its easy but i just cant find it... How do you move your characters weapon behind their arm... or moving anything else behind something?
2. Move the object to the wished position.
3. Either change the object's layer to one that is behind the other objects, or move its layer to place it behind the other objects.
1. Use LIST on the weapon to see which sheet it is on.
2. Open the Sheets & Effects dialog and move the respective sheet up in the list until it is above the matching ARM sheet. Sheets earlier in the list get drawn first and therefore appear behind other sheets.
Alternatively, you can use the "SendBehind" command (upper right toolbar).
1. Click the "Send Behind" button
2. Click on the edge of the object you want to move the weapon behind
3. Select the weapon, right-click, Do it.
The problem ist that in CA3 with all the overlapping symbols, it can be hard to "catch" the correct symbols. That's why I recommend the first method.
