Problem with islands in city builder
I'm starting a city map, and I'm totally overwhelmed. I'm using the tutorial in the tome of ultimate mapping as a guideline, but there's something I don't see addressed--how to add islands to a harbor after I've drawn the water in, and then to add buildings to those islands. I managed to get the island to stay (it was disappearing initially, because I was drawing it on the wrong layer, I think), but now I've got an issue with buildings I place on the island disappearing. I think the issue is that the island can't be on the same layer as the rest of the city land, because I had to draw it in after (and if I used the same layer, the water would be on top of it). Obviously, the islands should be on the same layer as the rest of the land, but drawing the river mouth and harbor in a way that leaves islands in the middle evades my skill.
Not sure what to do here.
I don't know how to include an image or screen shot of my map in my post to show where I'm at with this.
water sheet
building sheet
Otherwise the water will be drawn on top of the buildings.
not the layer..the sheet.
and you can move what you've already drawn to the proper sheet. using the change properties command
