converting a large narrow png to a cc3 overland map ?
For those who have been here for a long while, I'm still trying to convert the 151x191 pixel surface maps of my Crestar site to a larger hemisphere map. Still at it.
I have 14 world pages, each web page is 6 columns wide and 20 rows tall. 815 x 3513 pixels.
http://crestar.drivein-jim.net/worldall01.html is one of them.
When I import one of these pngs, to scale of 1110 x 4680 miles.
The CC3 map is tall and narrow, instead of being tall and wider in the png.
I'll attach png exports.
What I want to do, is import the original pngs and make maps of them.
When I import them, they seem very much narrower than the pngs I am using. The template is to scale.
However, the png export comes out as 332 x 1200 pixels.
If this sounds confusing, I am confused to.
But what I want to do is take the small pngs, and make them a big continent map. I know I'll lose lots of detail, that isn't a problem.
Thanks !
I believe one confusion source is the border you use.
The 332x1200 export is to scale with the 815x3513 assembly.
When you talk about a 900x1200 CC3 overland map, do you mean a 900x1200 CC3 template or is your map really thrice wider on your screen ?
If I understand what you want (not sure I do...) and if you still have the CC2 files of the individual parts, I would use the following
1. Export each CC2 map as a png without the border
2. Assemble all these exports (PhotoFilter has a nice Paste Special feature to do that).
3. Import the result in CC3.
As for the scale, I think I did export both pngs above as 50 percent of original size. The 900x1200 is the png export size.
What I want to do is make a continent map for the southern hemisphere. i already have the detail maps.
I'd still export the small maps without the border and glue them together with PhotoFiltre.
