Symbol set 2
I seem to be having problems with symbol set 2 in dungeon designer 3. It appears not to display the SS2B terrain bitmaps correctly in the program itself. In my explorer I can view these perfectly but not in CC3/DD3 itself. I'm running the program on a vista machine.
http://img269.imageshack.us/img269/4535/nofills.jpg
The outline for the fill is there, but the textures for all of them are set to blank. Ex:
http://img200.imageshack.us/img200/7131/fillsblank.jpg
I'm running on a Windows 7 machine. For installation, I followed the Vista instructions found here: http://www.profantasy.com/service/technical.asp?ID=67
If you need them in a regular DD3 map, the simplest way is to first start a new SS2 map, save it. Then start a new DD3 map, and select Insert -> file, and then insert this SS2 map. This will insert all the fill styles belonging to the SS2 map. Then, you can press Ctrl+Z (Undo), to remove the map you just inserted. This will remove the map items, but the fill style will remain, allowing you to use them in the DD3 map....
