Change color of symbol fill?
seycyrus
Traveler
I've drawn a town map using the John Speed method. In order to save time, I used a symbol fill across the river which is outlined in green. I'd like to have the green outline changed to black. I've tried change properties with out any luck. The fill symbol properties does not have a color option. In an attempt at a workaround, I added an RGB effects to the drawing and picked the predefined "sepia" setting. The result is shown.
The forest across the river is not MEANT to be a different shade than the town. I'd like them to be the same shade of black. The same thing happens when I pick the "unity" predefined rgb setting. Isn't there a way to edit the symbol fill so it is darker black? I.E. edit the symbol fill so it is black rather than green, resulting in the same shade under sepia.
