John Speed Map problem
I am going through the 07 annual and working on the John Speed map format. I cannot figure out how to draw a horizontal wall (i.e. parallel to the horizon). Is this done with one of the tools in the annual, or is just a drawn line with one of the standard tools.
Also, the pdf references the 45d drawing tool it when it first starts talking about placing walls. I cannot visualize how it is suppose to be used.
  • seycyrusseycyrus Traveler
    edited May 2014
    Select Spd Wall 20' 45dE and hit the up (or down) arrow key on your keyboard.
    That part of the tutorial was a bit confusing to me as well at first. Just chug ahead and place some symbols down (use the up/down arrow keys to get a perpendicular symbol) and you'll see how they should be placed. You will have to draw extra lines to connect some wall segments.
    Here's one I just started.
  • Thats what I needed, thanks!
