Wall cutter error
I'm experiencing an error with the wall cutting tool that leaves behind a symbol and if I try putting a door in, it does nothing to remove the wall. If I try putting in a door after the wall cutting or vice versa, it cants the symbol at an angle and won't let me lock in the correct angle I need. I've tried restarting the program and using different door catalogues from the different plug-ins. Here's an example of what the program is drawing:
The shape of the building looks great.
If you can't get the wall breaker tool to cut the wall try using the "break" tool instead.
- Open the Symbol Manager and find the Wall Cutting symbols in there. Delete them.
- In the catalog windows, open the catalog CC3/Symbols/Dungeons/DD3/DD3 Color/Wall Features.FSC.
- Now use the cutting symbols from that catalog. Do they work correctly?
