Random Street w/ Fractal Roads
                    I have the Random Street feature working fine on roads that I draw using the Roads in Path/Polygon mode, but when I switch to fractal mode, and then select a point on my Road (the same way I do it on path / polygon road mode), the houses end up getting drawn at some random point on my map instead of along my road.  When I say random, I mean that I didn't even notice it the first time I tried using the feature - the houses were completely across the map, and not connected to any road.  ONE time, I was able to get it to display two houses next to my fractal road, but I can't get it to happen again.
That being said, I'm really excited to get the fractal roads and random streets working together. I guess I can draw my own streets in that fashion, but it seems to me that if I can do it using a feature already built in, then that would be ideal :)
Has anyone else gotten fractal roads and Random Street to work? If so, can you please provide a dummy version for me? It's been years since I've used CC, and while I was "competent" at that time, I have forgotten almost all of it and have to re-learn.
But you can try to make the fractal path "smooth" after drawing it, as the street tool copes much better with smooth paths. Right-click the Explode button, use "Straight to Smooth" on your fractal path, and then apply the random street tool.
Hope that helps.
I can understand the "why" fractal roads don't quite work straight out with random street, but I'd be fine deleting the odd house that overlapped another house instead of not being able to have it follow the fractal road at all. The fractal roads seem to me to be an ideal solution for a "slum" area of a medieval city.
So that's where all the menu options I was used to went
That, of course, worked perfectly.
