Cutting Maps
Hello all,
I can't find the "keep" command in CC3 as described in the mapping tutorial for the 2012 annual - cutting maps.
Can anybody help?
Thanks a lot!
Can anybody help?
Thanks a lot!
KEEP is the text command that you can type into the Command Line. The button on the interface for that same command is the Extract Properties button
I hope that helps,
~Dogtag
I have one more question on the cut-tutorial. I finished the map as described but the zoom is still the same as in the first map (continent).
What can I do to adjust the zoom to the new map?
Thanks a lot again!
PS: Thank you dogtag, it worked!
